66 Coronet tie rod ends
djbr459
6:25 PM
Ohio
What's the difference between the inner and outer tie rod ends.
Left Hand thread -- IS -- the Inner....
Right Hand thread -- IS -- the Outer...
I have them NEW U.S.A. made, if you need or want....
Thanks for the info. Unfortunately I already have them but I will keep you in mind if I need anything else.
Hi, Does anyone have the torque specs for the castle nuts on upper and lower ball joints and the castle nuts on tie rod ends?
wide block,
Yes, I have them and much more....
I will P.M. you presently,
Yours, Craig....
