OK, here goes. I used a tape measure, so things are most likely +/- 1/16" or so.
Hood scoop back edge to back of hood is 3 1/8". Of course centered left to right. Cut out a cardboard template exactly the shape of the scoop, press the scoop down on the cardboard to locate the mounting bosses then make the holes in the template.
Now you have a perfect template to locate the holes on the hood.
RT side emblem, drivers side: Foward hole is upper,left and 21 9/16" from door jamb (hooking tape measure on jamb) and 15/16" above ridge line.
Rear hole is lower, right 24 5/16" from door jamb and 5/16" down from ridge line.
RT side emblem, pass side: Foward hole is lower right 21 5/16" from door jamb and 7/16" down from ridge line
Rear hole is upper left 24 1/8" from door jamb and 7/8" up from ridge line.
These dimensions are to the center of the hole too.
Make sure you double check everything before you drill especially the RT emblems. The scoop needs to be sealed to prevent rain from leaking through. And minor adjustments can be made by making the holes slightly bigger. A little slop won't hurt unless it's a lot of slop.
Take your time.
Hope this helps, my Rt happens to be sitting in paint only for the past 5 or so years.
I also can get you other measurements since there is nothing on it yet.
