- 9:02 AM
- Oct 16, 2014
- Salisbury, Vermont
Is there a front or rear to them, or does it matter? They are shaped differently on each end.
How bad is it to remove and reinstall one of the strut rods?Okay, thanks, now I have to take it all apart...again....lol.
Depends on how far apart the rest of the assembly is. For me I just have to take loose the pivot shaft lock nut, the rear end lock nut on the strut, and front lock nut on the strut. Slide it all to the rear and move the cups to face the other way. If your front end is under load, as in all together with torsion bars, shocks etc...then you are looking at a different job...use your FSM.How bad is it to remove and reinstall one of the strut rods?
