67 fan clutch
alextucker
3:41 AM
Ireland
The electric fan I bought just won't cut it, she really needs a dual fan to shift enough air. It just stays below nucular now.
So I'm going to replace the fan clutch instead as I think it's bust as spins too easy. But I can't find a 67 one. Will the 68 work? I can see the bolt holes to the pump are different but they may still fit. What you guys think of this one on jegs?
http://www.jegs.com/i/Derale/259/22043/10002/-1
I use Napa 271303 fan clutch. Looked the part up under a 1970 coronet with a 426 hemi. Its a HD clutch
You need to measure from the water pump face to radiator, that will tell you if you need the short clutch or not. On my 383, ECP radiator, I did not need the short clutch. HD clutch, 7 blade fan. Clutch face is 1/2 from radiator and the fan blades are dead center in the shroud(front to back)
