bcOH67
Looking for a wiper switch for a 67 charger. 3 speed or variable. Doesn’t have to be pretty, just working and not $200+. If that’s what they cost then I’ll bite the bullet eventually. Thanks
I'll look tomorrow, I'm sure I have one, I will check if it has the same number of prongs, (3 speed), mine came out of a Coronet.This is what I have. I have no idea if it’s original to the car. Wipers work fine but go off randomly by them selves. So I pulled it to see if it need cleaned and the little flat silver (ground?) strap is broke.
I'm not sure that is the problem, but it's a start. The 2 halves are soldered together from the factory so it should be no problem doing it again (with the switch halves assembled)Haha yeah, they will be off and just randomly start working. There is a little 90 degree tongue that bends out at the end of the silver strap and appears to connect to the other half, it is broken off. So I don’t even know what I’d solder or what needs to contact what
