Moparparts
This came from a 68 Coronet. The drivers side rear frame rail is good. The passengers side rear frame rail is bad in the back section, and the bumper mounting cross member will need sections or replacement. The rear seat pan section, tunnel pan, shock cross member, and inner wheelhouses are very nice used. Trunk pan has some small holes. Full clip, as pictured, with the inner wheel houses would be $350, and $275 without the inner wheel houses. I may also consider selling individual pieces, per enough requests. I also have for additional purchase, firewall, right front frame rail, torsion bar crossmember hinge pillar sections and more if needed from a 68 GTX. Pick up would be in Richfield, Pa 17086. post or PM if interested
