WTB 68 charger door glass rear guide channel
Grandbob
2:40 PM
Memphis
I'm looking for some decent door glass rear guide channels for a 69 Dodge Charger
Can you post up a pic of exactly what you need? 68 in your title or 69 in your post, are they different?
Can send pic later
I need the window guide channel that bolts to the door next to the lock assembly.
Channel is lined with flocked
Rubber it guides and adjust the door glass, this is for a1969 charger hard top.
70 should work, I'm not sure about 68
Mega parts has those frocked liners if you have the metal channels. If you don't have the channels, I think I have a pair. PM me if needed.
I'm interested to see what you have . My passenger side is the worst condition I didn't realize how bad it was until I took the rubber insert out I have new ones from Detroit Muscle. if you would have a look at yours under the rubber I realize they're going to be some Rust but I need a solid piece that I can clean up and use
I have a few if the guys in front of me don't get you fixed up PM me
Here are a pair that I have. Came out of a 69 Charger. Pretty much rust free. A little surface rust but will clean up nice. $40.00 plus shipping. Probably another $15-20.00
Looks pretty good it's hard for me to tell have you removed the rubber lining
when I remove the rubber from mine that's when I discovered how bad they were
if they are solid on the inside where the lining goes I think we have a deal .
3474 Tulane rd
Nesbit, ms.38651
I can PayPal you or whatever Arrangements you like
