'68 Coronet front bench seat question
SublimeSixpack
10:25 PM
Utah
Does anyone know for sure if the front bench seat (structure/dimensions) from a '68 Coronet 500 Convertible is the same as the front bench seat from a '68 Coronet Deluxe or Super Bee?
Should be the same.....No reason not to be. I have a '68 Coronet 500 vert and it looks like any other coronets front bench seat. Pattern design may be different between others, but that's it. Mounting is the same as well. Rear seat is definitely different than the others body styles for a convertible.
Thanks for the response.
Why I asked is because I have a '68 Coronet Deluxe and would like to buy/install seat covers that have the Coronet 500, and/or Coronet R/T seat cover design and pattern. I believe the only way to do this is to order the front seat cover for a 500 Convertible (bench seat), and the rear seat cover for an 500 or R/T hardtop.
I figured the convert front bench should be the same as any other '68 B-body two-door front bench but wanted to be sure before I place the order.
Thanks again.
