68 Coronet Postage Stamp Tachometer Wiring Harness
68wanabee
7:59 PM
Bonney Lake, WA
Does anyone know if the following wiring harness from Classic Industries will work with Postage Stamp Tachometer. I do not have the Rallye Gauges so, just want to know if this will work? Or if someone has a harness for this type of setup I would be interested in purchasing.. Any help or feedback would be appreciated.
[h=1]1968-70 B-BODY TACHOMETER WIRING HARNESS[/h]
http://www.classicindustries.com/mopar/parts/mb373.html
Thanks.
It looks like that harness should work. I have an excellent original one here with the number tag still on it from a 68 GTX and the connectors appear to be the same. Although there are slight differences in wire length and placement of some of the components.
Now, I just need to see if it will work with my electronic igintion or if I need to modify it in anyway to get it to work...
If you are running an electronic ignition, the tach will need the upgraded kit to read accurately. I had one done at Auto Instruments and another at Dash-Worx. There are several other companies doing it also.
