westjay194
Has anybody here done this swap & kept the 62-64 push button transmission?
It is a 62 dart the first b bodyWill it even fit?
The 60-62 Darts were not considered A body cars, right? Were they the first run of B bodies? If so, no chance it will fit without some serious modification.
The 63-66 Dart and Valiants used a K member unique to the chassis. The 1967-76 model A bodies had identical frame rail dimensions so any car within that range can accommodate any K member from that era. Outside of that, nothing else fits. Push button transmission fitment has nothing to do with the K member.
Yes the cross member has been modified, but it needs help.I think the OP is concerned about the trans crossmember working ???
Hey, Is English your first or second language ?It is a 62 dart the first b body
68 k member with 383 disc brakes
Is good. Problem with my tail shaft housing cracking.
Thanks for the great information.Hey, Is English your first or second language ?It seems like you are either confused with how to phrase your question or are very new to these cars and what stuff interchanges.
You realize the K member means the engine crossmember? No A body K member will fit a B body car no matter what year.
Also....A 383 has no brakes, drum nor disc.
Plenty of helpful people here BUT you need to ask questions in a way that makes sense.
Getten uppity.Maybe you are used to people that speak gibberish. I try to associate with people that don't speak "Wal Mart".
The thread title and content don't match.
Check you pinion angle relative to the drive shaft. It should be 3-5 degrees down. Had the same problem with our '63 until we added wedges under the axle perch to correct the angle.It is a 62 dart the first b body
