68 Road Runner trunk finish panel
roadrunnerh
9:21 AM
Pittsburgh, PA
Do any of you know who sells the white round foam circular gaskets that go over the studs?
For the studs, you have two different options. The first option is mastic sealer. The mastic sealer was used on various studs of this fashion where a barrel nut was used. If you should view the AMK on line catalog, go to page 167 and you can view them. This is actually a better sealer than the cellulose foam in my opinion.
Your second choice is to take a gasket punch and a sheet of foam that can be sourced from packing supplies or hobby stores. Cut out the number of seals needed and then use a hole punch and cut out the center hole.
You could possibly reach out to DMT to see if they have something that is close to fitting, but to my knowledge, they are not included in their paint seal kits and and the hardware kits for that panel does not include the gaskets as well.
If you do not find anything, we will have the mastic sealer inserts available at the upcoming Carlisle show.
