68 standard dash frame vs 69
68wagon
7:31 PM
Ontario
I know the ignition switch hole in 69 is bigger. Do the lower dash pad studs line up. Does the 69 ignition switch plug into a 68 dash harness and function?
The fuse box is mounted on a different place. They have a special bracket to hold it. The glove box liners are different because of this. Another concern for you.
