WTB 69 big block 727 driveshaft
I have one that is 52 5/8 from Center of u joint to Center of u joint. Yoke needs polishing, and new u joints needed to.
Dodge 52.07" Plymouth 51.5" with 8 3/4"
This one came out of a 69super bee with a 4 speed. At 52.5” (which maybe it’s my measuring that is off a touch) is only 3/8” longer than the number you have recited from the manual and should work fine for him depending on application. I have one for a 69B body, 6 cylinder, 3 speed manual also.
The OP must jot be interested as he hasn’t replied anyway. But if he see’s this I believe shipping from Alberta is around $70, I have 2 heavy cardboard tubes with steel ends to package it in too. Also it may actually only need the rear u-joint too, not both
