69 Charger brake pedal light switch.
Duda
12:38 AM
Vandergrift Pa
I have a 69 Charger manual brakes, 4 speed. I adjusted up all the brakes on the drums and now the switch is out of adjustment. The switch is not the style with the jam nuts to adjust the switch up or down. From what I’ve read there is a bracket that the switch bolts to and it requires adjustment. I think there is 2 bolts which are difficult to see or access.
Any secrets to accessing these bolts.
is this the correct method of adjustment.
Can the bolts just be loosened or do they need removed and the bracket reposition.
Mark
Loosen the bolts, moved the switch till it’s just about touching, tighten the bolts. Check to see if the brake lights turn off after pressing/releasing the pedal.
