WTB '69 Charger Parts List Needed
68n69 Charger
12:41 PM
Texas
Feedback: 1 / 0 / 0
Trying to line up the next "Last List" for '69 Charger.
Need the following:
-Vacuum canister and headlight actuator (1)
-Floor pan door seal plates (L&R) Pieces to seal off the carpet at the doors
-Wheel well chrome at each wheel
-Door handles (L&R)
-Door latches (L&R)
-Antenna assembly
-Wipers
-Hood latch bar mounted to hood
-Trunk latch assembly
-Drive shaft for 727 trans and 8 3/4 rear end
-Factory fan blade for a fan clutch
-Door panels (L&R)
-A pillar trim pieces
-Visors (L&R)
-Head Rests (L&R)
-Front dash panel at top of glove box
PM me with what you have available
i have the visors in b 7 blue very good condition i might have the drive shaft also i will have to look
Hello, I have some of the parts from your list (highlighted in bold red with notes):
-Door handles (L&R)
-Door latches (L&R) (I have the right side only)
-Antenna assembly
-Wipers
-Trunk latch assembly (I have the latch mechanism but not the striker bar that bolts to the trunk lid)
-Factory fan blade for a fan clutch (I have an 18" dia 7 blade fan blade for a clutch fan)
-Door panels (L&R)
-Visors (L&R)
-Head Rests (L&R)
I tried to PM you but your inbox is full.
Need the following:
-Door handles (L&R)
-Door latches (L&R)
-Antenna assembly
-Wipers
-Door panels (L&R)
-Visors (L&R)
-Head Rests (L&R)
your inbox is full
I have those carpet trim pieces. they are about 10" long that go behind the sill plate at the base of the rear panels?
I have both the door latch assemblies but not the strikers and I have the trunk latch but not the striker. Let me know if your interested.
@68n69 Charger I also tried to send a PM with info on parts available - your mailbox is full
Need the following:
-Door handles (L&R)
-Door latches (L&R)
-Antenna assembly
-Wipers
-Door panels (L&R)
-Visors (L&R)
-Head Rests (L&R)
Have vacuum canister and actuator, both handles and latches, 7 blade fan
