69 Charger Steering Column Shift with Automatic Transmission
robl72
2:45 PM
RI
The "Housing" with Shift indicator moves on the steering column when moving the "Lever" "Housing" to change gears. Not sure the steps to get it secured again. Do I need to remove the steering wheel and just tighten it down or is something else going on to cause this.
Any suggestions appreciated.
There are two bolts that attach the collar to the tube.... They require quite a bit of disassembly to access...
So I assume when you say dissemble that means I need to take off the steering wheel , bearing, turn signal and then I see the bolts?
