Landon
Hey guys,
I'm looking for advice on my car.
Here's what I got: 69 Coronet, 3500lbs, 727 torqueflight, 3.23:1 suregrip, 440 with mild cam, .40 over, edelbrock performer 440 intake, stock heads, stock exhaust manifolds, holley fuel pump regulated to 5-6 psi, MSD mechanical/vacuum advance distributor with 6A ignition and HSV2 coil, and a Holley 750 DP.
Here's my problem: If I ease into throttle the car is crisp and will smoke the tires when the secondaries come open:headbang:. If I stomp on it when the car is rolling or already has some RPMs same thing, it will take off:hello2:. However, When I stomp on it from a dead stop the car will die and/or bog until I let off the gas:icon_cry:. I'm pretty sure its carb related so I ordered a tuning kit (squirters, jets, power valves, pump cams). What carb setup would my car need??? Is carb too big/too small??? Or is this unavoidable with a DP on a heavy auto car with 3.23 gears out back???
Help is greatly appreciated,
Landon
Landon
