For Sale: Not Mine 69 dodge charger - $10,000, NOT MINE
GrabberOrange69
12:43 PM
Hops Capital USA
NOT MINE! 69 dodge charger - $10,000, Salem Oregon 1969 dodge charger for sale by owner - Salem, OR - craigslist
1969 Dodge Charger originally a 318/904 now a 340/727. Clean title in my name, vehicle runs and drives. The 340 is a 71 block, has a nice cam, unknown mileage on the engine was a pullout from a local truck and swapped in the car. New battery cables, new aluminum radiator, electric fan setup, new radiator hoses. Has 8 3/4 rear with 489 center section with 3.23 gears and suregrip, pinion bearing makes noise. Four wheel disc brake conversion on the car. Power steering, power brakes, all new stainless steel brake lines and hoses, new master cylinder, new booster, new proportioning valve. Installed tic toc tac cluster in the vehicle, needs to be wired up, original cluster will come with it. Vehicle needs sheet metal work like all B-Bodies, hole in the driver side toe board, small pin holes theoughout the floor. Trunk floor also has some holes, quarters should be replaced (come with the car), decklid is rusted through as is the hood, the hood is junk, I have a cowl hood that goes with It. NO TRADES, NO TRADES, NO TRADES!!
Scammer
It's also on eBay, located in PA
1969 Dodge Charger originally a 318/904 now a 340/727. Clean title in my name, vehicle runs and drives. The 340 is a 71 block, has a nice cam, unknown mileage on the engine was a pullout from a local truck and swapped in the car. New battery cables, new aluminum radiator, electric fan setup, new radiator hoses. Has 8 3/4 rear with 489 center section with 3.23 gears and suregrip, pinion bearing makes noise. Four wheel disc brake conversion on the car. Power steering, power brakes, all new stainless steel brake lines and hoses, new master cylinder, new booster, new proportioning valve. Installed tic toc tac cluster in the vehicle, needs to be wired up, original cluster will come with it. Vehicle needs sheet metal work like all B-Bodies, hole in the driver side toe board, small pin holes theoughout the floor. Trunk floor also has some holes, quarters should be replaced (come with the car), decklid is rusted through as is the hood, the hood is junk, I have a cowl hood that goes with It. NO TRADES, NO TRADES, NO TRADES!! Text 540252017three
(540) 252-0173
540-252-0173
Dr. Michael A. Pasternack, DC​
Chiropractor
609 Cedar Creek Grade Grade, B
Winchester, Virginia 22601
(540) 252-0173
1969 Dodge Charger | eBay
1969 Dodge Charger​
  • legotrainfan_0 (74)
  • 100% positive feedback
$30,875.00
or Best Offer
Deposit of $1,000.00 is required
VIN (Vehicle Identification Number):
XP29F9B379548
About this vehicle​
This 1969 Dodge Charger is a classic project vehicle that has been updated with a drivetrain to make it a more reliable and enjoyable ride. The owner has had the vehicle for 3 years and has put a lot of time into making it a great addition to any collection. The car is drivable and has been mainl y used for weekend drives. The vehicle has a red color and has a mileage of 99876. It is a great opportunity to own a clean title on this iconic car. Make your response short and to the point. This 1969 Dodge Charger is a must-have for any car enthusiast who is looking for a unique and challenging project.
Vehicle Details​
Don’t waste my time if you’re not a serious buyer.
1969 Dodge Charger originally a 318/904 now a 340/727. Clean title in my name, vehicle runs and drives. The 340 is a 71 block, has a nice cam, unknown mileage on the engine was a pullout from a local truck and swapped in the car. New battery cables, new aluminum radiator, electric fan setup, new radiator hoses. Has 8 3/4 rear with 489 center section with 3.23 gears and suregrip, pinion bearing makes noise. Four wheel disc brake conversion on the car. Power steering, power brakes, all new stainless steel brake lines and hoses, new master cylinder, new booster, new proportioning valve. Installed tic toc tac cluster in the vehicle, needs to be wired up, original cluster will come with it. Vehicle needs sheet metal work like all B-Bodies, hole in the driver side toe board, small pin holes theoughout the floor. Trunk floor also has some holes, quarters should be replaced (come with the car), decklid is rusted through as is the hood, the hood is junk, rear tail panel also has holes and so does rear valance. Hole in the torsion bar crossmember that could be patched, have a good used one that comes with the car. Driver door is rough, driver fender dented and rusted, I have a 6” cowl hood that goes with the car as well as an AMD one piece trunk floor, both full quarter panels from AMD, tail panel, rear valance, valance corners all from AMD, a rust free original deck lid, and an extra front valance. The motor has a CVF serpentine belt setup on it, with new water pump, converted to Mopar electronic ignition and a one wire alternator. Headlights and taillights work as do turn signals, headlight doors, and tag light. Had the front seats recovered with legendary seat covers and foam with new headrests and bezels.($3k) Rear seat needs to be recovered, no headliner in the car. Door panels should be replaced as well, no radio hooked up. I have a lot of extra parts with the car too extra taillights, housings, ac heater box, all the vinyl top trim, quarter extensions, the sheet metal listed earlier plus more. I did sand down the roof to bare metal, it’s not rotted through in any spots. Cowl panel has a hole by driver side A-pillar. Rear frame rails do have small dime sized holes right by rear crossmember.
New rear leaf springs, new shocks all around, new lower ball joints. New Cragar S/S wheels and tires. I know I’m forgetting a lot of what has been done to the car and what I have as far as parts. It’s a project car that has a lot of potential. Trying to be as straight up about the car as possible, will show it to anyone who wants to see it.I started stripping off some of the orange paint on the outside to reveal the red underneath, great patina car that you can enjoy and drive as you restore. I can send more pics upon request, can also send videos of it running. This vehicle is being sold as is where is with no warranty. I recommend that if you bid on this car that you come get it and all the parts, once the car is sold and paid for I will not be responsible for any damage or loss that occurs to it or any of the parts. Vehicle will also not leave my possession until the title is transferred and the payment has cleared my bank. Vehicle is for sale locally and I reserve the right to end the auction early. I had big plans for this car but don’t know when I can make them happen so I’m offering it up for sale. Any questions just message me, thank you.
Wow - great work. That's what I love about this site. In all seriousness, the add's closeness to Mark Worman and still up might have been a clue, lol.
