69 roadrunner
steve maluk
7:07 PM
johnson city tn
ok here we go again
if i want to drop a hemi in a 383 b body i need to change the k frame correct ?
what else needs to be changed ( suspension ) ?
hearing a lot of chatter about motor mounts - i have a 2468330-M mopar block
do they make aftermarket k frames? if so where can i get one - or any laying around LOL
will a standard big block 727 hold up to mild street use?
thanks
ok here we go again
thanks
Look at your block. I believe that block has both mount provisions. If true all the wedge mounts will work. Tranny will be fine if built right. Torsion bars might need adjustment or replacement. I would see how it sits. You will need Hemi headers or manifolds, dipstick and tube.
i think you need the bracket to reposition the brake booster too
