69 RR Front Right Turn Signal Housing Assembly
Shuboxlover
11:59 PM
Nebraksa
Feedback: +0 / =0 / -0
My front right turn signal is flaky. If I pull the wire down, the bulb will light, let it go and it goes out. If the socket is replaceable I need that. If it is not replaceable, then I need the entire assembly.
Please PM me with price (including shipping) to 68358
Thanks...
Mods....could you please edit the title to WANTED: 69 RR Front Right Turn Signal Housing Assembly
Sounds like the center round pin that normally touches the end of the bulb for power is loosing it's contact probably from 40 years of wear. I would build that pin up with some solder, that should fix your problem. If it is wiring you'd have to split the harness open.
The socket isn't really replaceable it has a funky way of getting crimped on the assembly.
Did you fix the one you have or end up buying a new one?
