Apologize for length of post.
Not working:
• all side markers
• all tail/parking
• dash
• stop
Working:
• headlights low and high-floor switch ok
• front and rear signals
• dome -only by door switch (not with door closed through dimmer roller)
• backup (I believe) and dash backup indicator
• dash brake system indicator
Did:
Continuity’s good on all fuses, reviewed electrical diagram to isolate circuits for not working items (but newbie experience) not 100% certain using thoroughly/correctly, with ignition on used a test light on female connectors for dimmer roller and light switches. Only dome circuit worked on dimmer roller connector, only (“L1” ?) lit for light switch connector. I don’t see “L1” on diagram. Is it lighting feed? Cleaned all contacts for fuse box and both switches.
The car was restored ~10 yrs ago but appears was in damp environment and shows moderate/high corrosion on connection points.
I found (so far) 3 wires that have been cut and wires twisted together without a connector used, believe it or not. Unsure if relevant.
• black/yellow stripe - right front marker and parking (why blinkers work?)
• black/white stripe under dash - on diagram is listed as “optional” which theorize is hazard which I don’t think the car has.
• I used a simple barrel connector on all 3 temporarily to at least know they are good connects.
• 2 other individual wires under dash connectors with spade connector. Heavier guage (12 or 14?) red, and 18 guage red.
Bottom line is I’ve gone about as far as what my very limited experience enables.
Any detailed thoughts on next steps tracking down the point of failure? A lot of info. Hoping it helps better isolate where the issue starts. THANKS!
Not working:
• all side markers
• all tail/parking
• dash
• stop
Working:
Did:
