70 GTX wiring
MoparBill
8:07 AM
Western New York
I'm slightly confused on the wiring for the carb solenoid and distributor wiring on a 70 GTX.... I have the FSM.... does anyone have good pics, or better yet- the wires I'm missing?
Not much around on them one hot wire goes to the vac advance teminal the other terminal with the pigtail part goes to the solenoid, when the car is turned off the vac advance retards 5 degrees and the solenoid de energizes. I have a couple of the plugs from the vac advance if needed. Do yourself a favor and test the vac advance they usually fail one side or the other.
I believe you tested mine when you did the distributor...
Oh snap forgot that! Finally getting it hooked up?
Bill any issues at all just give me a call. If you need the pictail just let me know just got a few on other broken ones.
