cdkmbjones
Good morning all, looking to probe the minds of the community. I have been working on cars and heavy trucks for 30+ years and recently came across an issue I need a little help with.
Did a power disc conversion on a 71 b body that came with 4 wheel HD 11" non power drum brakes. Bought one of the MBM "kits" wasn't thrilled with the look of the non OEM booster and off brand master and after installing it found my motor did not make enough vacuum either for the 8" dual diaphragm booster. The pedal was hard and stopping power terrible.
So, took it all back out and purchased an OEM 71 midland booster and all related bellcrank hardware from another 71 b body, had it rebuilt and restored. Installed it along with a reman 71 disc/drum master. Now my power brakes are beautiful but I can not get the pedal right. There is no air in the system - I have bled it with a power bleeder and a reverse bleeder - no air, nice clean streams of fluid. But the pedal goes right to floor. If i pump it, it builds a nice pedal and the car stops great. Wait three seconds and push again and it goes to the floor. I have adjusted the rod from the booster to the master right to the point of engagement. I have the rear shoes (with all new hardware, cylinders, drums, shoes) adjusted to the point of a slight drag. There are no leaks at any fitting and none of the rubber lines are expanding or collapsing - they are all new. as well. The front single piston calipers are new, with no leaks and after pumping the brakes, hold firm. The lines are all new, and the combination/ proportioning valve is new. After blowing my brains out on this, i've begun to guess - I never guess, but I am out of ideas and tests. I swapped out the proportioning valve - no change, swapped out the master - twice, once with a smaller 1.03 bore and once with a larger 1.15 bore and both times a new, not reman. The result is the same every time - the brakes work and the power assist is great, but it is like there is either air in the system - which there isn't, or like the pressure is not building and holding enough. I am open to ideas. I know there as been talk about bad proportioning valves out there made by inline tube, which is why I have not only used on of theirs but one from MBM - same result. It is more like the feel you get when the master is going bad - bypassing pressure internally.
