Jake
OK, I recently got my 71 Satellite back up and running after it's been sitting in my garage for about a year. Had it fired up, ready to move it out of the garage, dropped it into gear and........she won't move!! It's like the brakes are locked up. I tried to goose the throttle in hopes that it would roll forward, but she chirped the rear tires and would not budge. I triple checked the parking brake lever and it is not engaged. WTF?? :angry9:
A little background: the day before I pumped the brakes while it was running to make sure the brakes were going to work before I moved it. Well, the pedal went all the way to the floor:confused5:. OK, so I pop the lid to the master cylinder and...NO FLUID!! No biggie, right? I go to the local parts store and pick up some DOT 3, top off the master cylinder to about a quarter inch below the top and close it back up. Started the car, pumped the brakes and felt pressure. Got back out and open the master cylinder again to check the level, and added a bit more fluid. This time I noticed the color of the fluid was a muddy brown color. Not sure if that is good or not.
Anyway, I haven't any experience working on brakes other than changing pads and such and I am not sure where to start with this. She has drum brakes all the way around, and I plan on replacing the front drums with a disk system in the future, but for now I just need the car to be able to move and safely stop so that I can get her on a trailer and moved.
Should I bleed all the old fluid out and put fresh in?
Is there an adjustment that I need to make?
Any thoughts?
Jake
Any thoughts?
Jake
