71 Satellite filler over tag light
wahya
5:45 AM
Florida
I wound up with two and I neglected to write down which one came off my Sebring. The numbers are in opposite direction of each other and a lot different. The parts appear to be identical and they both came off 71s. Any ideas? Thanks.
i have both of those plus a different styled one
if my memory is correct..
the one with the T 32-1 is on my 71 rr
and the other one with the long number was on the 71 sat i parted.
there is also a third version
that did not use staples to hold the rubber strip on to the metal
instead it was a rivet head similar to what was used to hold vinyl top trim down.
Thanks, it seems that maybe they just put them on randomly, or after the supply ran out on different vendors.
