727 torqueflite
motorhead55
4:34 PM
Dover Plains NY
Ihave a 727 torqueflite from a 66 c body,will this work in a 66 sattelite bib block conversion with schumacher mounts? Had a poly 318.
Are you saying the trans came from behind a poly? If that's the case, no, it will not fit behind a big block. If it came behind a big block then yes, it will fit. 727s are all the same length in car applications.
