8 3/4 axle bearnig P/N?
Badvert65
8:16 AM
Brightwood, Virginia
I went online and have been having trouble getting the correct axle bearing for my belvedere. It is the axle bearing by the wheel. I need to replace both sides but the online listings do not list them on the 8 3/4. Basically, I need bearings and outer seals (I just replaced the inner seals).
It's always something...
sigh...
-Matt
After reading up on things, I have decided to go with the non-adjustable conversion bearings (with the snap ring). It's mostly a drag car so what can it hurt?
-Matt
8 3/4 part numbers
sigh...
-Matt
Here are the part numbers.
Jeff
Gaskets, Seals:
Position Chrysler National C/R Fel-Pro
Axle inner seal 4796698 8695S 15460 ---
Axle outer seal 2404216 8704S 19000 ---
Axle flange, foam 2070933 see flange kit see flange kit 55032
Axle flange, shim 2881314 see flange kit see flange kit ---
Carrier gasket 1673367 --- --- RDS 65833
Pinion seal, 1-7/8 2931862 5126 18708 ---
Pinion seal, 1-3/4 2931862 7216 18912 ---
Pinion seal, 1-3/8 2931862 8515N 18708 ---
Yoke repair sleeve --- 99187 99187 ---
Bearings:
Position Cup/Cone, Timken, BCA Notes:
Differential, side LM 104949/LM 104912 70-74, Borg Warner
Differential, side 25590/25520 57-69, Dana
Pinion, front M88048/M88010 1-7/8"
Pinion, front HM89443/HM89410 1-3/4"
Pinion, front M88048/M88010 1-3/8"
Pinion, rear M804049/M804010 1-7/8"
Pinion, rear M803149/M803110 1-3/4"
Pinion, rear HM89446/HM89410 1-3/8"
Axle, outer BCA A-7 65-74
Axle, outer C/R BR7 65-74
Axle bearing service kit: Chrysler # 3683966, one axle.
BCA differential kit: 1-7/8", # RA-301, 1-3/4", # RA-300.
BCA axle mounting flange repair kit: Left # A-7-LK, Right # A-7-RK.
C/R axle mounting flange repair kit: Left # A7-LK, Right # A7-RK.
Note: the 8-3/4" axle shaft outer bearings require packing with grease as they are not lubricated by the gear oil.
Thanks Jeff. I packed the OE bearings with High temp bearing grease and set the axle adjuster to about 0.020 clearance (FSM says 0.010-0.023). The dang thing has started howling recently, not super loud, but annoyingly so. Dang it, I just want to get ready for racing season. Sigh...
-Matt
