arizona satellite
I am building my 67 plymouth, the engine is as follows std bore 440, 10.8 to 1 CR 440 source stealth heads, (ported with mopar template and a flow bench, they are still at the machine shop so I do not have any flow numbers yet) comp 305H cam adjustable roller rockers(1.6). induction is eddy torker 2 with a Holley 850 four cornewr HP carb. Ignition is MSD 6AL-2 with MSD billit dist. headers are hedman street headers. trans is 727 w/"J" converter. the rear is undecided as of yet. I have an offer of a Dana 60 housing (1Ton truck) a set of MW 40 spline axles with a spool and 4.56 gears for 700.00, or should I build the 8 3/4? I have not cut the body and am not sure I want to, the dana stuff is for an A body or so I am told. I guess my question is, is it worth the extra cost to go with the dana or will a well built 8 3/4 live happily behind this combo?
