9.25 C-Clip Thickness
JedIEG
2:23 AM
Columbus IN
I have a 9.25 out of an unknown late 70's bbody for my 72 SSP. Its a 3.23 with limited slip and 11" drumbs so its way better than the 8.25 I had.
After hearing about c-clip failures from other c-clip axles, I would like some insurance and replace the ones in my rear end with new ones that I know have not been fatigued. Summit had two widths 0.175 and 0.205. Which do i need?
Just for an FYI My Dakota R/T has a 3.92 SG 9 1/4, and I've used it like a truck including towing cars across the state, and driven it quite a "spirited" way for over 15 years and 165,000 miles.
I can't find the pair I had for my 9-1/4" cone LS ('74). If I find 'em I'll measure.
You might give Dr. Diff a call on them.
After hearing about c-clip failures............
FWIW, the newer 9-1/4" corporate LSD does/did have a clutch pack retainer issue which some folks often referred to as "c-clip failure".
240,000 miles on my '99 ram with 9-1/4 rear ... no issues. Has regularly towed a heavy trailer its entire life.
