FJ6 v code RR
Mopar A body 8.75 with 741 case 391 gears and original clutch sure grip posi with doctor diff 4.5 bolt pattern axles. This is a ORIGINAL MOPAR A BODY 8.75. This 8.75 is all and I mean all redone. Has pictures to show rebuild. The 741 case has new bearings and seal the clutch type sure grip unit has all new bearings and clutches. The 391 gears are new old stock. The brakes are c body 11" 2" wide and are all new besides backing plates. The axles are new doctor diff 4.5 bolt pattern axles with green bearings. Brake lines are new Stainless steel and new brass block and rubber hose. Price is $3600 located in collins ohio 44826. Bolt in ready to go.
