mmmaaaxxx
Hello Guys,
i got a big problem to connect the wires of the A/C & Heater the right way.
My car is an 1966 dodge coronet with an ron francis wiring harness. 2 Years ago i deleted the heater because it was leaking, now i rebuild it and want to get it all back in the car. Everthing works perfect (replace the heater core, replace the seals in the box etc.), but the wiring of all the stuff is really hard for me.
My harness has 1 brown cable (called "heater", and the instruction manual says it should go to the heater switch for power feed). The 2 cables on the blower motor are green and black (i suppose black is "ground"), but where i have to put the green cable on?
I don´t know which cable is going to which connection...
Here are some pictures:
my heater blower switch in dash has 3 connections:
the resistor for the blower motor on the heater box has 6 connections:
...i think connection 4 & 5 are for this connector:
but the other connections i dont know.
my vacuum switch (which is in the dashboard) has the following connections:
Maybe somebody could help me out...i don´t understand the wiring in my shop manual because of my aftermarket harness and i can´t find something which helps me with the connections in the forum search or the internet. I only want to get the heater working, the A/C is still deleted...i don´t need it here.
Thanks & kind regards from germany
max
max
