A/C parts availability for 1967 Satellite
Max440
3:21 AM
michigan
Where can you buy parts for factory heater and AC box.. Mine is all original and not tampered with. I have no clue if anything works - Can you buy the water heater valve? I also have 2 vacuum actuators that have broken vacuum ports broken - Is the expansion valve availab le?
I have found some parts are available like heater and evaporator, gasket kits etc. I do not want to start rebuilding this unit if the parts availability is an issue or parts are too expensive.
I also researched Vintage and Classic air - If I use either on of those I have allot of holes to weld in the fire wall. So looking for options - Any input or direction would be a big help
This is what I used on my '67 Coronet along with their brackets for a Sanden compressor to convert to R134a. Will freeze you out in the hottest of weather. Easy install.
http://bouchillonperformance.com/ac_condenser_kits
HTH
Classic auto air can probably repair your bad or broken parts. Depending on the part there's also probably a member here with what you need.
I was going to call classic when I had a chance - When I talked to them before they said about 1,400 to rebuild mine plus freight both ways and that heater / ac is heavy . My heater core is bad and I assume the evaporator is too as it had the hoses cut off and sticks stuffed into the line connections
