A833 Overdrive Transmission
angeli rebeli
5:28 PM
Wisconsin
For Sale: A 833 Aluminum overdrive transmission with Big Block Bell Housing and 10 1/2" clutch, throwout bearing and pressure plate. Clutch and PP are very low time, almost new. $200. Will Accept offers.
Do you have the casting # off the bell hsg?
Any numbers off the trans? What is the diameter of the Input bearing retainer?
Would you sell the clutch beariong and PP seperately?
Any pics?
did you have this installed in a b body? are you willing to ship everything? does this come with shifter and linkage as well? if so im very interested
Interesting.. What was this in or going in?
quoted from this article: http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
1975 thru 1987 Overdrive 3.09:1 - 1.67:1 - 1:1 - 0.73:1 (Trucks used a 0.71:1 fourth)
"The Overdrive four speed was a regular A-833 with an overdriven gear set installed in place of the regular third gear. The shift lever on the side cover was flipped over to "fool" the shifter into shifting from second to fourth and then back into third, which was the overdrive gear."
"The Overdrive 833s used a giant 5.125" IBR and the super large input bearing behind the IBR as sort of a reinforcement measure."
im pretty sure the truck OD A833 and the car OD A833 is the same unit, same length and everything but im not 100% my 1980 D-150 has a OD A833 in it
-John
Someone buy, or trade and get this? sale over..
Do you still have the tranny for sale?
Is the transmssion still available?
