AC blower wiring help, 1972 Runner
sco440
11:30 AM
Western, NY
My question pertains to my AC blower wiring. According to my FSM p. 8-154 there is a green wire C5-14DGN attached to the air conditioning motor (assuming this is the blower motor). I have a green wire with a grey plastic boot plug plus a ground on the engine bay side of my blower. The FSM says this wire goes to the # 4 spot in the bulkhead. I am I reading it right? This powers the blower motor? When I hook it up like this I get nothing from my blower switch. What am I doing wrong?
I believe you are. Mine tells me to see that A/C insert with no wire coding on 8-154. The A/C wiring is on 24-65. Have you tested the blower motor to make sure it works? I would go check our 72 RR but it is in Arizona and the GTX is a non-air.
THX, it seems to be in the high med low blower motor switch. Got the blower to work by jiggling the switch but only on high level with ac lever on max. I have no med or low blower levels. Took the switch apart and cleaned terminals, no change. Do they go bad?
check the resistor between the switch and fan. If it is bad it is designed to only operate the fan on high.
The resistor with the 3 coils in the heater box? How do you check that?
