FOUND AC brackets and pulleys - SB
Machmeter1
11:04 PM
Dayton
Feedback: 8 / 0 / 0
I know it is the wrong forum, but since some FBBO members also have ABody cars or parts, I would like to reach out here too.
I am trying to collect underhood AC parts for my 69 Barracuda, LA 318 with a cast iron water pump (inlet driverside). Attached is a snapshot from the Plymouth 69 parts catalog and two reference pictures of the pulleys. Unfortunately, I do not have a good picture of the front AC compressor bracket.
I would need everything circled in red.
Thanks,
Wolfgang
The good years for AC. They changed the design when they moved the water pump outlet to the other side. Only pre 70 LAs were like this so it makes them more difficult to find. The later design sucks, belts flapped and need 2 since there was no idler to force the belt to have contact 3/4 the way around the compressor pulley. If you need good photos in your search I should have some for all the brackets when I restored my 318 Coronet.
Thank you, Jim, pictures are always appreciated. As a Goldmember, can you PM them to me?
Thanks,
Wolfgang
We have a 67 318 engine complete with a factory A/C system on it,
with power steering, and all the brackets and bolts. Just start a converstion
with us, and leave a cell number for pics. @Dodge33
Good evening John,
Thank you for the pictures, I really appreciate your help.
Unfortunately they are slightly different. I found some other, more detailed reference pictures, but they are not mine, so I need first to ask for permission to post them here.
Thanks, Wolfgang
Update, I received an promising offer, will mark the wanted add "found" once the deal is closed .
Thanks Wolfgang
