AMD rear quarter replacement help (70 RR)
RebelRider
2:11 AM
Texas
Does anyone happen to have pictures or a thread of the AMD panels where they meet up with the back glass corners? Im trying to install mine, and I want to make sure they are right.
AMD quarter ... they need some major massaging in those corners. Sorry - no photos BUT use your trim to determine the proper curvatures on each side.
I agree on the glass fitment, but I'm more concerned something is missing. Its almost as if there is a void for water to leak directly down into the trunk.
From watching some other threads on this, I think there's a corner piece that works into the mix
Keep in mind that these are rough fitment.
The dutch has nothing to do with those corners !! Left as is two things will happen (or not happen) ... 1) the side trim will be too long at the bottom - not a big deal it can be trimmed a tad BUT 2) the bottom trim won't fit at all - because the corner is about 1/2" too high - what I was trying to show with the yellow line.
