amp/volt gauges
davidl13
11:01 PM
Florida
i have a 70 super bee with a rallye dash
i have some questions perhaps y'all can help answer..
1 i need an alternator that provides more for the (ac, elec fuel pump, water inj, dual fan radiator,stereo w sub, etc....) how do I hook this up?
2. i understand i need to change the amp meter to a volt meter... is there one that will fit in the stock location? ( i have ordered a HD wiring harness from painless performance)
3. i am considering installing better gauges, does anyone know who makes a replacement set for the rallye dash?
thanks in advance for all your help on this and other questions i have had throughout this project
David
does anyone know of a direct replacement volt gauge for the amp gauge spot on a rally dash on a 70 bee?
ok, well no responses, however i found out that www.justdashes.com will calibrate the amp meter to whatever power level i am running from the alternator...
You could check out Dash-Worx. I have been e-mailing back and forth with Amanda amanda@rt-eng.com She says they use your existing gauge and reface it for volts so it looks stock. You then use their sending unit and limiter with no cutting of the original wiring harness. Sounds good, but I have not tried it myself. They have started advertising this service in MCG. Let me know if you go this route as I am interested as well.
I think this is somewhat of a dupe. Some are discussing this on this thread..
I don't know if that helps.
