Another disc brake swap ??
268RTs4ME
1:22 AM
Polpar Bluff, Mo. 63901
I have a 74 Sat, I am parting and was wandering if the spindles and valve would all work to convert my 68 Coronet RT over to Power Disc Brakes?? Will all these Parts Work?? Thanks
Yes they will. The only two things to keep in mind is those spindles are considered the "late" spindles which are a bit taller. The second is the caliper. If the fitting for the brake line on the caliper bolts to the bottom on a large square boss, it will hit. (OK, I don't remember if it hits the steering arm or the control arm, but it hits something, dangit.)
