Another round of dyno testing with the Thermoquad
70GS455
11:05 PM
Madison, AL
After finally recovering from major engine damage when the motor swallowed a screw, I was finally able to resume testing. I tried 4 carbs, here are the best 2: a modified 6322 850 Thermoquad and a 0-80805BK Holley 950 Ultra HP (this is the 1.60" venturi version so it's a true 950). Both were fat to be on the safe side and the Tquad was the richest of all so actually there are probably at least 6 to 8 more numbers in it.
The secondary configuration is: stock HSB/emulsion orifice at 0.035", air door at 0.900" to the back bore, 0.143" jets, 90 degree butterflies, spray nozzles with a big .125" hole in the ends.
As part of the testing I wanted to characterize power vs door opening. This is what I found:
Door HP
.750 595
.800 604
.850 609
.900 617
The Holley was 611 hp, 621 ft lb, the Tquad 617 HP, 620 ft lb.
And forgot to mention that the TQuad has had the primary venturis removed from the plastic bowl, still retains both boosters
So what's the resulting increase in airflow from that mod?
