another tire question 67 satellite
67steve
2:36 AM
Fl
will a 28 x 10 x15 fit on the 67 satellite if so what rim width and bs
thanks
also anyone running a spool on the street?
really not a single reply !!!
Put it on a 7" wide rim that has at least 4 1/4" backspacing and it will fit. If you use an 8" wide rim it will need 5+" of backspacing or you will have tire rub up inside the outer wheel house.
a spool on the street is dangerous,, u cant take curves with out rear wheels chattering and can cause axles to break,, get a sure grip u will be much better off!!
I've heard a 15x8 with 4.5 back spacing with a 255/60/15 is the biggest you can go with no problems or mods
28 inch tall will fit but rub the rear of the wheel well upon any bumps....7 inch wheel works nicely but a 255 by 60 by 15 is almost the max...some have run an 8 inch with modified backspace on a 275 by 15....the cars don't like real wide tires....I have one...67 R/T
A P255/65x15 is equivelant to 28x10x15...the tire size the Original Poster asked about (Can one actually find a P255/65x15?...I don't know)
How tires are measured:
P255 is the width in mm (approx 10"s).
65 is what the percentage of the width the sidewall equals.
65% of 10"s is 6.5"s.
6.5"s x 2(top & bottom of sidewall) = 13"s.
13"s of sidewall + 15"s of rim opening = a 28" tall tire.
A P255/60x15 is equivelant to 27x10x15.
The (P255) width stays the same (approx 10"s).
60 percent of the width is 6"s.
6"s x 2(top & bottom of sidewall) = 12"s.
12"s of sidewall + 15" of rim opening = 27" tall tires.
The 28" tire diameter is only a half inch bigger than the P255/60x15 when measuring from the center. There is ample room for a 1/2" increase in diameter on my `66...which is the same as a `67. The problems most owners run into are from using wider wheels and not enough backspacing. It is a fine dance on the `66s & `67s when making a tire/wheel choice.
Here is a great site to 'play' with tire sizing. http://www.rimsntires.com/specs.jsp
