I need the pivot assembly for the driver side wing window. The pivot, the gasket, metal disc (washer) and screw. I am hoping this will solve my loose wing window problem. Thanks!
The pivot is held in place by means of a metal clamp that pinches the pivot between the vent frame and clamp and tension is set by how tight the screw is tightened. The upper pivot has no effect on the resistance of the force of the pivoting action.
