bee71
Were all stamping plants say in the case of a fender, using the same dies or were there discrepancies depending on where in the country they were produced and sent to assembly plants.
I'm not sure about stamping operations in the 60s but I have worked for Chrysler for almost 30 years and most plants do not stamp their own parts. Twinsburg OH was a major stamping plant until it vlosed in the early 2000s. Warren truck and Sterling Assembly both have stamping plants next to them and supply other plants as well. Belvidere added an on site stamping plant in the 90s for the neon. Other than those I think Mexico must have stamping plants too. The most recently closed plants in Newark and St.Louis did not have their own stamping plants that i am aware of.Typically, dies for sheetmetal parts were used
at the same plant where the car was
manufactured, or were vendored out to
suppliers within close proximity to the plant
to cut down on shipping and engineering
cost. There was rarely an instance where two
vendors cranked out the same part at two
separate locations. Factory parts must
remain available for a certain time period
due to warranty issues. After that, proprietary
rights are released, and parts can be produced
by different manufacturers after purchasing
either the original dies, or build their own from
the manufacturer's original drawings.
At least that's the way it was when I worked
for GM, then for the company that bought
all rights to the 04 GM Motor Coach.
Belvidere doesNo plant in the Chrysler organization stamps their own parts within their own assembly plant.
They stamp all their own parts? I've been gone for 12 years, I stand corrected if they started something new.Belvidere does
Not all of their parts are stamped there but alot are. There are 4 press lines and the ability to stamp most of their own but because of company politics Belvidere stamping is under utilized for the Cherokee model so we also get alot of parts from warren and sterling stamping plants too.They stamp all their own parts? I've been gone for 12 years, I stand corrected if they started something new.
If I remember correctly the LA plant was strictly an assembly plant,parts were shipped in from other facilities.
I didn't work for Chrysler in the sixties and seventies, but, I've known dozens of people who did. I worked in every corner of the building, top to bottom and knew everyone and their jobs. There was no quality in the early years, period. There was no need for it. You basically had three car companies in this country and the other foriegn cars makers didn't add up to much. Everything was done by people and make no mistake, some things just weren't held real tight, so to speak. When I got there they were just starting to phase out using lead for filler. They could run dozens of parts the were stamped wrong before they caught it and then they just shipped them. We started with one robot to get the windshield sealer applied uniformly and when I left they had 849 and fit and finish went up expeditiously. I have no problem believing your cars had different tolerances.Had a 70 Challenger that I bought a NOS rear trim piece for....the one that's argent silver and covered the trunk key area and had the end trim pieces. Heck, can't remember what it's called. Anyways, it fit my 70 ragtop but not the car I bought it for. Each car had been built at different locations. It was 1/4" wider than the one I wanted to use it for and neither car had been wrecked. Another E body had a wider wheel house on one side vs the other side. Go figure. Body sheet metal wasn't always on tolerance....at least for where it was built.
