B-Body drums to disk upgrade
shopguy
12:46 AM
NJ
65 Belvedere with 4 wheel drum brakes. I want to go with Mopar slider disks.
I think I can use the stock UCAs, as they are large ball joints. What should I do about lower ball joints? what do I use? I plan on using F/J/M spindles, 10.87" rotors. MC from a 70s Drum/Disk coronet....
Mike
specifically, I need to know if the stock OEM lower ball joints for a 65 drum set up will bolt directly to the later FJM disk spindles. I know the Uball joints will match the spindle.
thanks. that makes the swap even easier! no LBJ to change!!
