backing plates
RSZ28
1:09 PM
Brownsville, PA
Finally got around to disassemble what I think is a 66 B body rear end that has a sure grip that I bought years ago. I plan to install a rear disc brake kit, so I don't need the drum brakes that were on this. The backing plates measure 11" across and the brake pads that were still on them measure 2 1/2". I know someone might be able to use them. However, I have never sold any Mopar parts, so I don't know what I should value them. I'm not trying to get rich, just fair market price. The drums are not salvageable, but everything else is there along with axle seal and adjuster. Thanks
$30-$50 dollars on a good day. Installing disk brakes on the rear, I recommend using green bearings on the axles. I experienced problems with one setup due to the slight in/out movement of the axle on the standard setup.
