FOUND ball joint assembly mounting bolt
wahya
11:42 AM
Florida
Feedback: +3 / =0 / -0
Looking for a bolt and castle nut that attach the steering arm ball joint assembly to the brake assembly mounting plate. Looks like somebody smacked this one a few times and I had to cut the nut off. Thanks. (71 Sat)
(3" long x5/8)
Theres is specialty aviation surplus hardware store that sells ones that were the proper size for my 1964 plymouth fury front drum brakes. They have all kinds of hardware there if know the size I'm sure they have it. If you cant find them elsewhere I could send you some from that store.
They're drum brakes. I went to local bearing and bolt place and bought bolt, but it didn't have hole for pin. Don't know if I can drill one without messing up threads. So I would probably be better off with the correct one.
I likely have one. I'll try and see what I have tomorrow, just came in from helping put engine and trans in my son's Ram.
It's quite cold out there... 23F
These ones have a hole already machined in them for a pin. It's a specialty aviation surplus hardware store with tons of unussual hardware that regular hardware stores would never have.
