Texas charger 73
will SE front and rear door panes fit in a 2 door base coupe? should all be same just SE more fancy?
From 71-74 they all interchange Plymouth, Dodge B bodies. Take care
Nacho is right. Also little known fact that you could order a hardtop as an SE and still keep the roll down quarter windows.
Mine is a high hardtop according to fender tag. Whatever that means
hardtop means actually no B pillar post
Since on Chargers there is not an actual B pillar post ( except 73/74 SEs and those 74s with M07 roof option, but it means nothing on unibody ), then Coupes are a fixed glass mounted on a bracket and simulated B pillar post through the vertical seal molding ( WL21 VIN ). Hardtops are same look but roll down ( WH23 VIN )
You might want to check your dash VIN and fender tag against the cowl VIN or the rad support VIN.
