Bell housing question
old guys rule
8:00 PM
Jacksonville, FL
Is there a physical difference between Bell housings for a big block 10 and a half inch and an 11 inch fly wheel?
Yes, depends on year:
The bottom cover is different for each size
the 66-67 B engine 10.5 iron has a small pilot hole
the 67 440 11” iron has a small pilot hole
The 68-69 383-440 11” Iron has a medium pilot hole
The 1970 10.5 aluminum has a medium pilot hole.
The Mid 70’s OD 4 speed has a large pilot hole
(for reference)
I don’t know if a 64-65 bell if it will fit a 66-70 b-body on the cluch pivot mount
The starter mount is also a bit further out on the 11", so it only works with the 143 tooth flywheel.
maybe I have a 10 and 1/2 in Bell. I bought it from Keesler several years back. How can I identify between the two? I have the 143 tooth flywheel. Starter gear has 10 teeth.
Maybe I have a 10 and 1/2 in Bell. The flywheel is 143 teeth and the starter gear has 10 teeth. What's the easiest way to tell the difference? I bought this bill from Keesler a few years back so it's not OEM.
Call keisler since there are no factory numbers to identify it.
Or, does it have a pilot hole for the starter snout? Then measure from the centerline of the starter snout hole to the centerline of the hole for the trans. Then someone can measure a factory bellhousing and compare.
Thanks oh, I will measure it. Problem is Keesler is out of business.
thanks, I'll measure it. Keesler is out of business.
