Belt(s) for a 440
BamaCharger66
10:46 AM
Alabama
Trying to order or buy belts from part stores for my 440. It is a 1966 440 with power steering. It is going into my 1966 Charger. The crank pulley has 4 or 5 grooves. Guessing I’ll need two belts? Anyone have lengths needed or part numbers? Thx!
I probably can help you out when i get back home around noon today
It sounds like your engine came out of a car that had air conditioning, if it has a 4 groove pulley. Do yourself a favour and get the proper non-AC pulleys for your motor, because the alternator and water pump are driven differently too. Check the pulley size on your power steering pump, because there are a couple of options here. Rock auto lists all the belts you need. I have a 1967 Coronet R/T with power steering and 440. Belt number on it is 11415, with TRW pump, 5 3/4" pulley.
