FOR SALE big block heads#516
k/sa
1:53 AM
cicero ny
Feedback: 1 / 0 / 0
I have a set of 516 heads all one piece valves,intakes are FERREA 208,exhaust are INDY 160,all are single locks,5 angle valve job,pc seals ,some port work on exhaust side,heads were done last year,5 passes on my drag car,600.00
these heads also come with steel shim head gaskets,springs 911, can not ship pick -up only
What was your E/T s with these heads? What was the car weight?
car ran 11:60 with a 383 ,weight 3550 dodge dart, MP solid lifter cam,the intake side of these heads are untouched, 516&915 heads are totally different.
Any work on the intake throat you can show? I just had a set of 915 heads done and would like to see some sample work if you don't mind
