FOR SALE Big block parts
FJ6 v code RR
1:46 PM
Collins Ohio 44826
Feedback: +3 / =0 / -0
440 .60 over seal pro pistons part number L2266. $200
I also have 440 steel 4 speed crank and LY rods for extra. $400
I have two big block power steering pumps wood brackets 150 each
Two sets a big block rocker arms with shafts 100 each
1969 date code starter 100
62-65 b body engine mounts and rubber insulators. $100
I have a 3 peace big block automatic transmission kick down linkage, as well as other big block kick down linkages for b/e body cars and big block trucks. 3 peace kickdown $200 and big block kickdown $100ea
Big block engine motor mounts.$80
Starter heat shields.$20
Max wedge rocker stands.$150
IMG_20190127_153559378-1002x1336.jpg IMG_20190228_133555573-1336x1002.jpg IMG_20190430_155754964-1336x1002.jpg IMG_20190430_155745904-1336x1002.jpg IMG_20190228_133544312-1336x1002.jpg IMG_20190430_161336015-1336x1002.jpg IMG_20190228_135216194-1336x1002.jpg IMG_20190228_134304493-1336x1002.jpg IMG_20190430_161514136-1336x1002.jpg IMG_20190228_143642180-1336x1002.jpg
I see power steering pumps. You wouldn't happen to have any power steering coolers would you? Thank you. Mike
Do you have the 440 4 speed crank still would you sell just the crank and how much
I have a set of 452 big block heads comes with rockers and valve covers. $200
Come off a low mileage engine a little cleaning and valve seals they will be ready to bolt on and go already has hardened seats for unleaded fuel. Stock valves.
IMG_20190608_181009272_TOP-4008x3006.jpg IMG_20190608_180946454-4008x3006.jpg IMG_20190608_180920255-4008x3006.jpg IMG_20190608_180718841-4008x3006.jpg
